Radiator fan problems
Old Jan 24, 2006 | 01:44 PM
SpoonREVS's Avatar
Default Radiator fan problems
Ok so i notices my radiator Fan is not working also my temp needle doesnt go up. I check the fuses and there all good. I put direct power to the fan and it works but when i plug it back it never turns on. What other points should i look at and check? Or does any one lknow what the problem might be.
Old Jan 24, 2006 | 03:15 PM
old man neri's Avatar
Default Re: Radiator fan problems (SpoonREVS)
could be a viraity of things. Is you car actually getting warm enough? The fan is only suppose to kick on after a long time of idling at a stand still. It could be as simple as your thermostat being stuck open and thus your engine never gets warm and your fan never needs to turn on.
Could also be some sensors have failed or their connections.
Have you felt the hoses to see if they are hot or cold or warm?
Old Jan 24, 2006 | 05:42 PM
Ruben19's Avatar
check the fan relay and coolant fan switch on the thermostat housing. if not check thermostat./
good luck....
nfiniti9
Jun 9, 2012 02:14 PM
KINGVEM^^ED6
11
Mar 11, 2012 08:04 AM
jkalex05
Aug 22, 2009 07:02 AM
Donhonda84
Apr 4, 2007 08:36 PM
hybrider
Jul 23, 2002 08:21 AM
