weird tapping noise?
Old Jan 24, 2006 | 01:19 PM
philosofy1's Avatar
Default weird tapping noise?
maybe someone out there can help me? i have a 93 civic hatch dx. when i drive around 40mph i get a tapping noise on the left front side, this also happens when i brake right before i stop. it's loud enough to hear with or without the window open, but not loud enough to pin point, and it isn't constant (only at 40mph & braking). my brakes are good & replaced the axle like a month ago. i jacked the car and spun the wheel and heard nothing, started the car and gave it some gas and still nothing. it's driving me crazy, could my bushings need replacing, or maybe my ball joints. i need an alignment, can that be the problem?
can someone help w/info or any suggestions?
thanks!
Old Jan 24, 2006 | 01:24 PM
snatch's Avatar
Default Re: weird tapping noise? (philosofy1)
Check the balljoints. Jack the car up, grab the wheel at 3 and 9 o'clock and shake back and forth. Then do the same at 12 and 6 o'clock. See if there is any play. Check the boots on the balljoints to see if they're torn, check the tie rod ends for play, and the upper balljoints as well.
Old Jan 25, 2006 | 02:12 PM
philosofy1's Avatar
thanks for the advice, any other suggestions. has anyone else have this problem or something similar?
Old Jan 25, 2006 | 06:08 PM
MikeD718's Avatar
i have the same thing going on with my EK hatch. i need answers too!
Old Jan 26, 2006 | 05:01 AM
sheBangZ's Avatar
maybe its coming from your head? mine does the same thing and turns our i need a valve adjustment.
Old Jan 26, 2006 | 05:44 AM
dpkelly's Avatar
Default Re: weird tapping noise? (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">Check the balljoints. Jack the car up, grab the wheel at 3 and 9 o'clock and shake back and forth. Then do the same at 12 and 6 o'clock. See if there is any play. Check the boots on the balljoints to see if they're torn, check the tie rod ends for play, and the upper balljoints as well.</TD></TR></TABLE>
12 and 6 o'clock doesnt really work. Grab the steering knuckle (that metal thing next to the shock spring) and rock back and forth. If it moves or u here a noise, it's your upper ball joint. You can do this without jacking up the car.
dopesk8er87
27
Apr 9, 2013 07:51 PM
...rohit
Sep 10, 2009 12:43 PM
Kasur
Feb 27, 2008 02:53 AM
tico
Jan 15, 2008 03:41 PM
Ming Tsai
Sep 22, 2006 09:05 AM
