Type R swar bar fit EF9???
Old Mar 22, 2002 | 05:11 PM
evo's Avatar
evo
New User
Default Type R swar bar fit EF9???
Will Type R swar bar fit EF9? Either front or rear.
Thanks
Old Mar 22, 2002 | 06:26 PM
eg6ajk's Avatar
Default Re: Type R swar bar fit EF9??? (evo)
rear yes it will work, i used to have it on my EF
basically what you will need first is LCAs which can accept a bar. next complete bar....crossmemer will need to be drilled tapped/drilled to make holes for the brackets....
very simple just reinforce it so that it doesn't go through
Old Mar 22, 2002 | 07:56 PM
CRX7's Avatar
Default Re: Type R swar bar fit EF9??? (eg6ajk)
Get a suspension techniques rear sway bar, then you won't need different LCA's on the rear.
[Modified by CRX7, 4:57 AM 3/23/2002]
Old Mar 23, 2002 | 08:39 AM
REX VT's Avatar
Default Re: Type R swar bar fit EF9??? (CRX7)
New Type R swaybar is cheaper
Old Mar 23, 2002 | 09:29 AM
Todd00's Avatar
I said I don't want a title!
Default Re: Type R swar bar fit EF9??? (REX VT)
Suspension Techniques rear sway is only $125 and it saves you a buttload of work. Plus, you won't need new LCAs and everything. ST ends up being a lot cheaper in the long run.
Old Mar 23, 2002 | 09:37 AM
REX VT's Avatar
Default Re: Type R swar bar fit EF9??? (Todd00)
Not where I live
Old Mar 23, 2002 | 10:04 AM
evo's Avatar
evo
New User
Sound a lot work involve, i'm just looking for some sway bar fit straight on. How about EG SIR or del sol SIR? Are they stronger than stock EF9?
BTW what's LCA's
Thanks everyone...
Old Mar 23, 2002 | 10:53 AM
Todd00's Avatar
Rear sway: EG = DC2 = DC2R. So if one is a PITA to fit, they all will be.
LCA = lower control arm.
If you can get it cheap, just buy the ST piece and save yourself the hassle.
Old Mar 23, 2002 | 04:15 PM
jdmhondageek's Avatar
damn look at that someone who knows whats up
ST
Darrell
Honda Fit
Mar 26, 2007 08:29 PM
Jugga
Suspension & Brakes
Jan 16, 2007 10:25 PM
fightback
Nov 26, 2006 10:14 PM
sc_92_civic_hatch
Jan 26, 2004 11:47 AM
