VTEC NOT WORKING!!!!
Old Jan 24, 2006 | 12:20 PM
speedhatch's Avatar
Default VTEC NOT WORKING!!!!
my vtec is not working, not sure why, i think it might be a bad solineoid, but im not sure what else it could be. can anyone help? thanks
Old Jan 24, 2006 | 12:22 PM
x93coupex's Avatar
Default Re: VTEC NOT WORKING!!!! (speedhatch)
if its not throwinng a code it could be the solenoid check all the wires
Old Jan 24, 2006 | 01:23 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: VTEC NOT WORKING!!!! (x93coupex)
check your oil level.
Old Jan 24, 2006 | 01:24 PM
SOL Food's Avatar
1) VTEC solenoid
2) lack of oil pressure (lack of oil)
Old Jan 24, 2006 | 01:26 PM
s_vares's Avatar
check your oil. Do you have a CEL? if not, unplug the green wire on the solinoid and put it to 12V, if you hear a click, its prolly working the engine should idle poorly with 12 v to the solinoid. If not, remove it and clean the 2 little screens and check the O-rings for cracking. Replace if needed.
STeve
Old Jan 24, 2006 | 01:50 PM
speedhatch's Avatar
ok i will check, thank you!
nomoracin1030
Mar 31, 2019 07:47 PM
fer
Oct 20, 2017 01:40 PM
macDelli
13
Feb 12, 2011 11:28 AM
hondahead'
13
Aug 3, 2009 07:11 AM
onesikcivic
Jun 22, 2005 11:20 PM
