Spark plug wire keeps popping off dizzy!!!!!
Old Jan 24, 2006 | 09:55 AM
DeDonDeRosa's Avatar
Default Spark plug wire keeps popping off dizzy!!!!!
could a spark plug wire popping off the dizzy not completly would throw a cel for random missfire correct????
i have taylor wires and the number 3 moves and almost falls off maybe i need to adjust them like push the connector out a lil more listen for it to click in the dizzy and then slide the boot over
Old Jan 24, 2006 | 10:29 AM
Default Re: Spark plug wire keeps popping off dizzy!!!!! (DeDonDeRosa)
bump
Old Jan 25, 2006 | 07:40 AM
ANYONE?
Old Jan 25, 2006 | 07:51 AM
Sam92Teg's Avatar
Looks like you answered all your own questions nicely. The ends of the wires should sorta snap into place, if they don't, then pull the boots back a bit and collapse the connectors alittle so that they will snap in place at the dist. cap end or plug side end, then snug the boots back. Make sure that the wire holders aren't pulling at the wires. Also make sure the plugs are torqued to 7 lb/ft.
Old Jan 25, 2006 | 08:05 AM
Default Re: Spark plug wire keeps popping off dizzy!!!!! (Sam92Teg)
the plugs should be at 13ft lbs by every book i've seen
Old Jan 25, 2006 | 10:01 AM
92integraVTECgsr's Avatar
buy OEM Honda wires or NGK wires. They are the only wires that FIT directly and stay on. I had trouble with MSD.
Now I use OEM Honda. They fit perfect, and stay on all the time.
Old Jan 25, 2006 | 11:21 AM
old91teg's Avatar
Default Re: Spark plug wire keeps popping off dizzy!!!!! (92integraVTECgsr)
I'll second that. I bought an Integra recently with MSD wires and they wouldn't stay on. I swapped them for my NGK's off my wrecked car and the problem is gone. Now I just need to get rid of the shitty Bosch Distributor the car came with. Anyone want to buy some used MSD wires?.....lol
DELshaneSOL
19
Sep 25, 2011 02:58 PM
DrivinVtec
Oct 12, 2006 09:20 AM
jsrusse11
10
Nov 7, 2005 05:20 PM
JDMlyfestyle
Jul 21, 2005 09:29 AM
KekeK-18
Oct 19, 2001 08:51 AM
