Install of wiring to EG Foglights?
Old Jan 24, 2006 | 08:31 AM
StalX's Avatar
Default Install of wiring to EG Foglights?
Hi.. Need to figure this out
1: + wire to Foglights
2: ?
3: Switch
4: ?
5: ?
6: ?
7: Ground
8: Relay
9: Plugs to the Switchsbox under the steeringwheel (2 and 5 is standing on them)
But what about the rest, where do they go? Dont now what they are for
Old Jan 24, 2006 | 08:51 AM
fms1day's Avatar
Default Re: Install of wiring to EG Foglights? (StalX)
Shouldn't there be one to the battery's positive (+)? unless that's what #1 means. My DEPO foglight wiring harness looks different from that but here's what I remember. I had two harnesses, one for the engine bay and one for the cabin/under dash.
Engine Bay Harness:
Battery positive (+)
to Relay which then connects to
Right foglight then to
Left foglight which had a
Ground wire and also a
Connector wire that connected to the cabin harness
Cabin/Underdash Harness:
One that connects to the Engine Bay Harness that leads to three plugs:
1)Brown one that went to the fusebox's 2 or 4.
2)Another ground
3)Green plug that connected to the switch.
That's how mine was.
[EDIT] Your harness doesn't look like it has the necessary slack to reach from front of your car (Bumper: Basically where the foglights are) into the cabin where the switch will be. Unless the photo is cutting it off.
jdm_h22
Feb 8, 2008 08:20 PM
92 CIVIC HATCH VX
31
Jun 12, 2006 12:19 AM
pmendoza
Mar 31, 2006 04:21 AM
Markb16a
Nov 17, 2005 05:56 PM
Rusty Shackleferd
Jan 25, 2005 11:28 AM
