B16A Cam Setup Without Cam Gears?
Could I put a set of Crower Stage 1's in my B16A without upgrading the camgears? I do intend to give the head a light skim, and then if I install the Crowers at TDC will all be cool?
What I'd like to know is will it be worth getting the cam gears. I'm sure that they will make a difference if they're properly tuned, but as an interim solution will they work well if I just 'bolt-them-on' (the cams)? Will there be a decent increase?
without tuning don't expect to get gains from aftermarket cams...the key to cams as with any other setup is tuning.
if i were you just hold off until you can afford to buy the gears as well then install em both at the same time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MARSH »</TD></TR><TR><TD CLASS="quote">without tuning don't expect to get gains from aftermarket cams...the key to cams as with any other setup is tuning.
if i were you just hold off until you can afford to buy the gears as well then install em both at the same time.</TD></TR></TABLE>
