All must go So CAl
Old Jan 23, 2006 | 10:09 PM
Chain Driven's Avatar
Default All must go So CAl
MAKE AN OFFER ON WHAT YOU LIKE
coming soon pm if interrested
ran for less than 1 mile
JG Sleeved GSR 84mm Bore
wiseco 84MM 8:5.1
eagle GSR rods
stock stroke
stock gsr head
stock cams
aem cam gears
drag turbo kit
t3t4 turbonetics turbo
evo turbonetics wastegate
blitz blow off
intercooler
looking to get
$3500
__________________________________________________ ______________
B Series trans
Type-R Gearing
4.7 final
Circuit works drag spool
Carbon coated sincros
$1500
Tilton Clutch single plate
$700
Circuit works Axles and hubs
$700
JG Engine Dynamics
Assembled and balanced by JG
LS block Sleeved
LS 89MM stroke crank
Probe LS Rods
Wiseco 14.1 86MM Bore pistons
Stock oil pan, pick up
Circuit works oil pump
ran only five events
still has cross hatch
$1500 sale pending <U>getgot22</U>
B16A head
Ported by alaniz
black nitride flat vales
supertech springs and retainers
$1500
RPM 70mm Blank Throttle body
$200
MSD 7AL 2,Msd coil,2step,2 rmp switches, and Msd plug wires B series
all six items a $700 value
$400
Place racing motor mounts 92-92 civic or 94+ teg
$175 shipped
Shift linkage with gsr shifter and gsr **** $150
__________________________________________________ __________________
1600cc injectors set of 4
$150
MSD 6AL
$125
B Vtec valve cover black
$75
B Vtec valve cover glass bead
$60
LS oil pan, windege, pick up
$50 each
Post mounts 1st gen b series
$15
Magnaflow Muffler
$20
Ross HC pistons 86mm
$200
Airtech fuel pumps inline
$20
EG6 Bosch head lite booster
$25
90 CRX head lights
$35
PR4 Chipped ecu
$90
MSD RPM switch with 4500 pill
$30
GSR timing belt new in the bag
$40
92-95 civic engine harness
$50
98 LS Engine harness
$50
95 gsr stock diff
$30
Jason
562-307-6552
LA area
PAYPAL
pamdeg6@hotmail.com
Modified by N.O.B. at 7:05 PM 2/12/2006
Modified by N.O.B. at 7:08 PM 2/12/2006
Modified by N.O.B. at 8:11 PM 2/12/2006
Modified by N.O.B. at 8:12 PM 2/12/2006
Modified by N.O.B. at 7:24 AM 2/13/2006
Modified by N.O.B. at 7:14 AM 2/16/2006
Old Jan 24, 2006 | 05:17 PM
Default Re: All must go So CAl (N.O.B.)
TTT
Old Jan 24, 2006 | 06:07 PM
92bseries's Avatar
can i get a price on the gsr timing belt? shipped to 41042, i need one
Old Jan 25, 2006 | 08:08 AM
Default Re: (92bseries)
Replied
Old Jan 25, 2006 | 07:52 PM
Bumped
Old Jan 26, 2006 | 07:48 AM
TTT
Old Jan 26, 2006 | 05:37 PM
taking offers
Old Jan 26, 2006 | 06:52 PM
Civicfighter's Avatar
how much to ship to 10151 for this B series v-tec assembly $25? thanks
Old Jan 27, 2006 | 05:57 AM
Default Re: All must go So CAl (Civicfighter)
30
Old Jan 27, 2006 | 06:50 AM
LvN's Avatar
LvN
Is that a JDM Type R tranny? Any grinds on it or other problems? Where you located?
Old Jan 27, 2006 | 02:17 PM
Default Re: All must go So CAl (blkcivicpn0i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkcivicpn0i &raquo;</TD></TR><TR><TD CLASS="quote">Is that a JDM Type R tranny? Any grinds on it or other problems? Where you located?</TD></TR></TABLE>
no its a made up type r in norwalk ca
Old Jan 27, 2006 | 02:18 PM
and no grinds
Old Jan 27, 2006 | 02:31 PM
LvN's Avatar
LvN
Made up tranny? From what? What's the specs, gearing wise?
Old Jan 27, 2006 | 03:06 PM
type r gearing with 4.7 final and spool
Old Jan 27, 2006 | 03:13 PM
LvN's Avatar
LvN
Is it the JDM 98 spec ITR gearing or the 98 spec USDM gearing?
Old Jan 27, 2006 | 04:35 PM
JDM
Old Jan 27, 2006 | 07:07 PM
bump
Old Jan 27, 2006 | 09:45 PM
up
Old Jan 27, 2006 | 11:38 PM
JohnnieChimpo's Avatar
That 3.07 first gear, does that include the mainshaft since it is the other half of the 3.07 ratio? If so what is the ratio on 2nd gear on that main shaft?
Old Jan 28, 2006 | 06:14 AM
Default Re: All must go So CAl (JohnnieChimpo)
no it comes the way it came from ats Just the gear
Modified by N.O.B. at 7:35 PM 1/28/2006
Old Jan 28, 2006 | 06:35 PM
TTT
Old Jan 28, 2006 | 07:51 PM
How many miles on the Place racing motor mounts 92-92 civic
or 94+ teg $200? thanks
Old Jan 28, 2006 | 09:12 PM
race car miles about 50 miles
passes and dynos
Modified by N.O.B. at 12:36 PM 1/29/2006
Old Jan 29, 2006 | 05:24 PM
bump
Old Jan 29, 2006 | 07:19 PM
ttt
