Turbo mini me build DYNO
Old Jan 23, 2006 | 08:27 PM
175Shot4Door's Avatar
Default Turbo mini me build DYNO
Im going to go turbo on my mini me with a cheap ebay xs power turbo kit and im going to buy eagle rods and buy a turbo cam and diffrent pistions...mid build the head for turbo or low compression mabe a low compression head gasket and run a 50 shot... WHAT kind of wheel HP am i looking at ..anyone help plz project is starting im looking to see what im going to have? ??????
Old Jan 23, 2006 | 09:34 PM
imm0rt41's Avatar
Default Re: Turbo mini me build DYNO (175Shot4Door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 175Shot4Door &raquo;</TD></TR><TR><TD CLASS="quote">cheap ebay xs power turbo kit</TD></TR></TABLE>Not a whole lot, since you get what you pay for. Do yourself and your car a favor and save some cash and build a real kit.
Old Jan 23, 2006 | 10:19 PM
exotik4doorcivic's Avatar
Default Re: Turbo mini me build DYNO (imm0rt41)
do not get the cheap kits off ebay, i sked about those myself and read posts about the manifolds cracking the first day and the turbos splitting in half,you would be better off spending the $700 on a used kit from someone off ebay, or building your own,
i got a 14b turbo with an hx manifold downpipe all intercooler piping spearco intercooler, bov, fmu, oil pan w/ lines vac lines only 750 free shipping
Old Jan 24, 2006 | 10:05 AM
Default Re: Turbo mini me build DYNO (exotik4doorcivic)
can u hook me up from where u got ir from plz???...im looking for 220 wheel hp on a stock mini me with 140,000 miles on the head and 97,000 on the block im plaing on buying eagle rods and je pistions and a low compression head gasket
Old Jan 24, 2006 | 12:16 PM
look to about spending a 1000 all together on a custom kit
type in sohc turbo on ebay theres usually about 5 put together kits on there ranging in between 5- 800 if your looking into getting about 220 to the wheels then your going to need to run boost at about 10-11 depending on the kit you buy or a custom kit. to be safe i would get a bigger fuel pump,injectors, and a fuel pressure regulator which costs about 200 on ebay and some good fuel mangement
Modified by exotik4doorcivic at 9:28 PM 1/24/2006
Old Jan 25, 2006 | 07:34 AM
try going to your local junkyard and finding a hx manifold and a saab turbo or an eclipse turbo and start from there
Wagovan_AK
Jun 12, 2013 05:03 AM
ProjectMolly13
Mar 10, 2013 12:28 PM
dc101
Sep 30, 2011 06:38 AM
b20vtech
May 13, 2009 11:35 AM
Type R 00
Nov 20, 2006 04:49 PM
