Ignition power lose, take a look i need help on this!
Old Jan 23, 2006 | 08:26 PM
JDMIntegraB16's Avatar
Default Ignition power lose, take a look i need help on this!
alrite, when i try to crank turn on the car, well first off when i turn the ignition on the lights on the gauge cluster are dim(oil, and the other one) adn the ebrake light is just fine. but when i try to crank it over all lights will shut off. and when go back to igntion on the fuel pump will repump itself, and it will do that everytime i try to start the car. i thought it would be main relay but it wasnt. could anyone give me an idea of what is goin on, people say bad grounds, mite be but what ground to look for? and where to look for it at, people say bad main relay well cross that out. i dont know what to do anymore. if i try one more thing on this car and it doesnt fix it its meeting a baseball bat. thanks people
Old Jan 23, 2006 | 09:52 PM
sam385's Avatar
Default Re: Ignition power lose, take a look i need help on this! (JDMIntegraB16)
is the battery good?
have you checked the engine-to-chassis ground(s)???
are the connections to the battery and starter clean and tight?
Old Jan 24, 2006 | 09:04 PM
jdeemseerx's Avatar
first off i would take a multimeter and check that your batter is good.. around 12.6 not running...if that checks out ok then go to your connections make sure they are tight and you have the ground on the starter hooked up, then go to other grounds battery ground, grounds on the thermostat housing and even valve cover ground.. if you dont hear it cranking at all try tapping on the starter with a screwdriver and a hammer try all that and tell us what happens
Rhdae86
Jul 30, 2011 07:38 AM
Rhdae86
Jul 29, 2011 05:44 PM
Khmi
Jul 21, 2009 11:57 AM
Bboy_Trevstuh817
Dec 19, 2007 03:15 AM
jdm_vtec
10
Aug 3, 2007 07:39 AM
