vibration
Del sol...no accidents, stock 14's from a saturn, new tires, balanced, aligned, rear lower, front upper, front lower braces, car shakes at 50-55 mph under load with top off. Top on no problem through all gears from 0-100 mph. Top off fine through all gears until 50-55 mph. Checked car thoroughly from underneath no structural problems no bolts loose. And now Im stumped, from everything I have done the only other thing is maybe a weight fell off. Any suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pure Sol »</TD></TR><TR><TD CLASS="quote">top on its fine</TD></TR></TABLE>
Sounds like it's just the wind buffeting. Trying rolling up and down the windows when it is doing it to see if it stops.
The car is lowered 2.5" on skunk2 springs. It isn't so much a rattle as a shake, to explain it best when driving and approaching 50 mph I can watch the top (near the sun visors) shake. It feels like I am drving through a series of rumble strips. I have tried windows up and down but no difference. Axles are brand new but Im not saying everything brand new is perfect, I've had many brand new things screw up from factory.
yeah doesnt make any sense. having the top on or off affects the wheel balance about as much as having your stereo on or off. theres no way the 2 are connected. now if the top is rattling or vibrating when its on that would be something different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onegreedy »</TD></TR><TR><TD CLASS="quote">sounds like worn bushings, with top off there is more wind resistance so it affects the car more,
get front end checked out</TD></TR></TABLE>
yeah, but there isn't more wind resistance with the top off at 50 than there is with the top on at 100, where he said there is no vibration.
well as much as it doesn't make sense it happens. Nothing has changed since i bought the vehicle 2 years ago, externally that is. Front end has all brand new poly bushings. Im going to get it looked at for balance and alignment this week, any way to check the axles for inbalance?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pure Sol »</TD></TR><TR><TD CLASS="quote">Front end has all brand new poly bushings. Im going to get it looked at for balance and alignment this week, any way to check the axles for inbalance?</TD></TR></TABLE>
do you mean polyurethane suspension bushings or motor mount bushings? I have both in my car, but when I added the suspension bushings, I did notice a lot more road vibration/noise. Its pretty much the same whether the top is on or off though.
yeah both motor and suspension bushings. This isn't just road/noise vibration. Its not nearly a vibration as a shake. Im leaning towards a balance issue in the axle or wheel/tire. Ill keep posted.
