Injector Size 411
Old Mar 22, 2002 | 01:29 PM
comptechgsr's Avatar
Default Injector Size 411
ok, i need information on what the best size injector i should use...
i'm running stock GSR CR with toda b's....
270/310/440...
r there any rules for size? like the higher the CR the larger the cc's?
thanks guys
Old Mar 22, 2002 | 01:48 PM
Rhetoric's Avatar
Default Re: Injector Size 411 (comptechgsr)
hey comptech, what valvetrain are you using with the toda b's?
Old Mar 22, 2002 | 01:50 PM
Evil DOHC's Avatar
Default Re: Injector Size 411 (G S R)
98-01 Prelude injectors will do you well. Larger than stock I believe 270's and will save you money. Direct bolt in.
EVIL
Old Mar 22, 2002 | 02:11 PM
Default Re: Injector Size 411 (Evil GS-R)
thanks y'all, i like how we post in the ITR forum
these fockers, know their ****....u guys too, seems like the integra forum is aiite
the will i lose power if i go 310 or 440
how big r the stock gsrs compared to the ludes
also, i'm running toda valvesprings and portflow ti retainers
Old Mar 22, 2002 | 02:46 PM
Black R's Avatar
25 Year Member
97+ prelude injectors are 290cc/min
310's are the biggest you can go (reasonably) with stock ecu or you'll have throttle response and idle problems
if you have a standalone, go with 440-450's and compensate - that way you can run stock fuel pump and pressure.....
negusjuda
10
Feb 9, 2013 10:13 PM
MCP486
Apr 16, 2003 09:37 AM
SpeedFiend
Mar 25, 2003 04:24 PM
sneakychaos
Sep 17, 2002 05:37 AM
sneakychaos
May 10, 2002 05:56 AM
