GSR in EF - Tranny Troubles
Old Jan 23, 2006 | 03:50 PM
PurEvl's Avatar
Default GSR in EF - Tranny Troubles
I have a 95 GSR longblock and 89 JDM LSD SI tranny in my EF.
My motor is running perfect....the tranny however is messing up...
The tranny goes through gears fine when the motor is not on. When its on it wont let me into gear.
The throw out bearing, clutch, pp is perfect. The fork and cables are not bent.
I tried adjusting the cable but it still won't let me into gear. I played with the cable for a good hour. Tightening and lossing it trying to test it.
The shift linkage is hasport with enegry suspension bushings.
Everything is installed perfectly....could the LSD in my tranny be fucked up not letting me into gear when the motor is on??? It is hard for me to find nuetral when just shifting through gears when the motor is off. When on...the only thing there is is nuetral...I can't notch it into gear ...it just slides back and forth in nuetral. I can't go into any gear or feel any notches for the gears.
Is my LSD locked up causing this?
Old Jan 23, 2006 | 04:02 PM
EFSiR's Avatar
Default Re: GSR in EF - Tranny Troubles (PurEvl)
get under the car, disconnect the shift linkage from the trany and try if you can shift right at the trany. Let us know the results.
Old Jan 23, 2006 | 04:04 PM
PurEvl's Avatar
I did that before putting the tranny on the longblock and it shifted foward and backward...I don't really know which way to push/pull it to select a gear. As listed above...It does go through the gears when the motor is off.
Old Jan 23, 2006 | 04:13 PM
EFSiR's Avatar
Default Re: (PurEvl)
Just try it now with the motor and trany installed. So, if you want to shift it into the 1st gear, it's as if you where shifting into 2nd...
Old Jan 23, 2006 | 04:33 PM
paopao's Avatar
Default Re: (EFSiR)
Really sounds like you need to adjust your cable. Did you tighten and loosen it all the way? Or just a couple turns?
Old Jan 23, 2006 | 04:34 PM
boostinaintez's Avatar
Default Re: (EFSiR)
have a buddy push down the clutch while you watch the shift fork move back and forth. does it move?
Old Jan 23, 2006 | 07:44 PM
PurEvl's Avatar
I have played with the cable for an hour as I said up top. Loosened all the way and tightened all the way...no difference.. The fork moves without problem.
Old Jan 23, 2006 | 07:56 PM
ghost_ryder35's Avatar
if the fork moves I would assume the car is shifting fine... weird... interested in finding out what is wrong with this car... I would take the cable out and tighten it all of the way with it off the fork, and then reinstall it and pull as hard on the clutch cable as you can up while you tighten it down... That's what I had to do to get it tightened right
Old Jan 23, 2006 | 08:11 PM
paopao's Avatar
Default Re: (ghost_ryder35)
Yeah, I had to tighten my cable all the way too.
Old Jan 23, 2006 | 08:13 PM
crxnj's Avatar
Default Re: (paopao)
What clutch cable are you using.? The stock one,,?I know if you get a 90-93 integra cable you have more adjustability compared to the stock one..
Also does it go into gear while the car is off with the clutch not de-pressed.? It should go into every gear without the clutch pushed in..
Old Jan 23, 2006 | 08:21 PM
C1CRX's Avatar
Traffic signal tech
Default Re: (Mr.speaker)
maybe your master or slave cylinder??
Old Jan 23, 2006 | 08:23 PM
crxnj's Avatar
Default Re: (lvcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvcrx &raquo;</TD></TR><TR><TD CLASS="quote">maybe your master or slave cylinder??</TD></TR></TABLE>
He has a cable tranny though..
Old Jan 23, 2006 | 09:00 PM
C1CRX's Avatar
Traffic signal tech
oh **** my bad i didnt read your whole post
Old Jan 23, 2006 | 11:01 PM
EFM_ookie's Avatar
Default Re: (lvcrx)
when the car isnt on it goes through all the gears without the clutch pressed.... still triny to figure it out.. thanks for the help though guys TTT..
Old Jan 23, 2006 | 11:11 PM
crxnj's Avatar
Default Re: (89_Mangina_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89_Mangina_SI &raquo;</TD></TR><TR><TD CLASS="quote">when the car isnt on it goes through all the gears without the clutch pressed.... .. </TD></TR></TABLE>
That's a good thing you know..
Old Jan 23, 2006 | 11:15 PM
PurEvl's Avatar
I think it is a faulty LSD causing the problem.
Tranny is getting looked at today.
Old Jan 24, 2006 | 04:15 PM
PurEvl's Avatar
Found out the ACT pressure plate was from a 94+ hydro tranny....which can't be used with 90-91 cable trannys even though it fits...THANKS FOR THE HELP GUYS!
Old Jan 24, 2006 | 04:27 PM
o ya
linkdeezie
Transmission & Drivetrain
18
Feb 4, 2019 07:34 AM
88HATCH(:
Oct 20, 2011 10:40 AM
ADAMnQuickRDX
Jun 30, 2009 01:02 PM
b20vtecv8killer
Dec 18, 2004 11:12 AM
servion
Jan 29, 2003 10:39 AM
