H22 Type S into 6th Gen Accord?
Old Jan 23, 2006 | 03:00 PM
Excelerate's Avatar
Default H22 Type S into 6th Gen Accord?
I've read the threads on a 92-95 H22A into a 6th gen Accord but what about a H22A Type S into a 6th Gen? Any differences in terms of bolting it in? Obviously the Type S will be OBDII so how will the harness be setup? Which ECU? Any help on this would be appreciated?
Old Jan 23, 2006 | 06:03 PM
Excelerate's Avatar
Default Re: H22 Type S into 6th Gen Accord? (Excelerate)
bump for some help
Old Jan 23, 2006 | 08:16 PM
Legendaryyaj's Avatar
I wold think its exactly the same as just another H22 swap into the 6th gen body which has ben done over and over again. The Type S differences is all internals only so I doubt it will affect installation process. What's wrong with the boosted F23?
Old Jan 24, 2006 | 08:10 AM
Excelerate's Avatar
Default Re: H22 Type S into 6th Gen Accord? (Legendaryyaj)
Yes, but I need to know if there's any differences. I'm not doubting it won't bolt it like the others. I'm wondering about the ECU and harness. The Type S is from a 97+ car so it shoudl be OBDII. Obviously I'll use the Type S ECU but how will it work with the cars' electronics and how will the harness be done? Etc...
Bump for help.
Old Jan 24, 2006 | 11:14 AM
Excelerate's Avatar
I know there has got to be someone on H-T that has some insight on this.
Old Jan 24, 2006 | 11:24 AM
NAiL05's Avatar
Try searching around im pretty sure there is some info but not much on sixth gens. Maybe V6P has more information on it? They have quite a few sixth gens there.
Old Jan 24, 2006 | 02:42 PM
Excelerate's Avatar
Default Re: (NAiL05)
bump for info
Old Jan 24, 2006 | 03:00 PM
Nick H's Avatar
New User
Default Re: (Excelerate)
it will go in the exact same way...if you are lucky enough to find a real type s ecu, the pinouts are the exact same as that of a p13...use a swap guide for an obd2 h22 into a 6th gen and you'll be all set...the sensors, wiring, etc, will all be the exact same as that of the regular h22...
JDM_JNKY
Aug 23, 2010 08:04 PM
thao0094
Jul 16, 2007 07:17 AM
92SleeperH23
Feb 16, 2005 09:18 PM
prelude93si
Oct 7, 2003 03:48 PM
KW2000
Sep 21, 2003 12:51 AM
