which water pump? mini me (kind of)
a6 block
y7 head
y7/y8 timing belt
which water pump? y7 or y8 or a6?
i assume whichever timng belt i use i whould get the water pump to match-right?
just making sure before i buy the parts. already have the block(in the car) and my head is coming back from the shop end of the week.
thanks h-t
also, how do you guys feel about using a 88-89 pg7 ecu with this setup as opposed to a stock pm6?
y7 head
y7/y8 timing belt
thanks h-t
D15b7 timing belt works..
The a6 and y8 water pumps both have the same size gears and teeth count so it doesnt matter..
D16a6 block,waterpump,tensioner, and a sohc vtec head ,,use a d15b7 timing belt,,You can also use a d16z6/d16y8 timing belt but its really f*cken tight,,
Also the pm6 would be better since its for a sohc..But without having the right maps for the vtec motor its useless to have the vtec head..In my opinion you should get the pm6 chipped with turbo-edit and run the one wire vtec setup..You have a 90-91 pm6 right..?? http://xenocron.com/te.php?page=TEvtec
CivicxTree754
Nov 15, 2011 01:23 AM
YumVTEC
Sep 27, 2004 11:54 AM
davken1102
16
Jan 10, 2004 09:24 AM
