wheel repair shops in Michigan? please help!!
I've got two (yep TWO) pot-hole damaged wheels that I would like to get repaired before the weather starts clearing up. They have pretty light damage that I believe is repairable. Does anyone know of a shop that does this work and how much roughly is it to do? Thanks a lot.
Ryan
Ryan
Actually there is a place in Raleigh, NC called The Wheel Exchange and another called Hubcap Heaven in Suitland, MD. Both do excellent work and have 800#'s. (If you need a set (4) stock Base rims-I can be persuaded to part with mine.
Time for a bidding party.) You will find that the cost of repair versus outright purchase is not cheap even for 2 and you will see the results and want to do all of them anyway.
Another idea is to find a wheel shop near Detroit that specializes in motorcycle wheels-these guys are unreal in their ability to fix a rim. I had several aftermarket rims done and you cannot see where the repair is. I suggest this as these shops work on all sorts of exotic pieces. If near Pittsburgh-contact A&M Wheels in Ben Avon, PA @412-766-6464.
