tach wire help
Old Jan 23, 2006 | 12:45 PM
1sikhatch's Avatar
Default tach wire help
ok i just swapped in a b series in my eg and now my tach doesnt work, but i noticed that on the plug that goes to the distributor it is blank where the big blue wire goes. so i want to know if i can hook a wire from the blue wire on the distributor to the single blue wire on the drivers side shock tower to make the tach work?
Old Jan 23, 2006 | 04:52 PM
1sikhatch's Avatar
Default Re: tach wire help (1sikhatch)
dfcgftfe
Old Jan 23, 2006 | 08:02 PM
E.Honda's Avatar
try and see...if it comes on it works,,,,if it don't.....doesn't work.
Old Jan 23, 2006 | 08:42 PM
Cute EK's Avatar
Default Re: tach wire help (E.Honda)
I usually just splice an aftermarket tach in there when dealing with a car with no tach.
Old Jan 24, 2006 | 02:27 AM
1sikhatch's Avatar
Default Re: tach wire help (Cute EK)
well i wanted my factory tach working, i dont like does big aftermarket ones.
Old Jan 24, 2006 | 06:50 AM
92vx-t's Avatar
If all else fails, just run it to your ecu.
Old Jan 24, 2006 | 06:53 AM
1sikhatch's Avatar
Default Re: tach wire help (92vx-t)
anyone know which wire is the tach wire by the passenger side shock tower or which wire by the ecu?
Old Jan 24, 2006 | 06:55 AM
96CivicBoostCoupe's Avatar
you should just be able to run a new wire, i had to when i got my msd 6al box because my tach went nuts
Old Jan 24, 2006 | 07:05 AM
Ruben19's Avatar
there is 2 black and yellow wire. one connect to the module and then the coil. this will be your positive. your negative will hook up to the - of the coil
Old Jan 24, 2006 | 09:52 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch &raquo;</TD></TR><TR><TD CLASS="quote">so i want to know if i can hook a wire from the blue wire on the distributor to the single blue wire on the drivers side shock tower to make the tach work?</TD></TR></TABLE>
short and easy answer. yes.
This is a typical problem when using some ODB2 engine harnesses and an OBD1 chassis harness. (some OBD2 engines received the tach signal to drive the tach from the ECU not the distributor)
Old Jan 25, 2006 | 03:19 AM
1sikhatch's Avatar
Default Re: tach wire help (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">
This is a typical problem when using some ODB2 engine harnesses and an OBD1 chassis harness. (some OBD2 engines received the tach signal to drive the tach from the ECU not the distributor)</TD></TR></TABLE>
thanks man, hooked it up and my tach is working. just didnt want to hook it up and with having a chance with something else goin wrong.
Old Mar 14, 2006 | 09:19 PM
N1 Andy's Avatar
R.I.P. Andy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">short and easy answer. yes.
this is exactly the problem im having...https://honda-tech.com/zerothread?id=1552540 any help? back from the dead...
Tyson
40
Jun 4, 2009 04:24 PM
littleblue
Nov 4, 2008 08:29 AM
esean93
Aug 23, 2008 10:33 AM
bbhockey19
10
Jul 11, 2006 09:10 PM
NeedACivic
May 7, 2003 01:57 PM
