injector install price?
You should be able to do it yourself. Just:
unplug stock injectors
unbolt fuel rail (3 10mm bolts)
remove fuel rail
switch injectors (be sure o rings dont tear)
install is reverse of removal.
remove fuel rail
what kind of injectors and what year is your car?
for my 2k gsr w/ rc 440's, i needed the adapter clips which means i gotta tap/cut the old clips and solder the new clips on ... not exactly bolt on but just a little more time consuming if you're not comfortable cutting/soldering wires.
remove fuel rail
remove fuel rail
Not that easy. He has different plugs and the RC do not plug right in. You will need to cut out your stock injector plugs and use the 95 Integra plugs or the RC plugs.
i believe that RC uses obd1 like plugs which means that if your car came originally with obd1 clips , they should be plug and play !
I am assumming that his gsr is not OBD1
