Clutch question
Not to sure what could be causing this, its kind of randomly and just suddenly started happening, but whenever i ease out the clutch whole front end of the car vibrates and shakes a lot.
Usually you should be able to slowly disengage a clutch and take off with no gas, but in my car if i try that it will just vibrate really bad and stall out.
any ideas?
any ideas?
only like 9k miles on the clutch, the flywheel has been replaced with a 9 1/2 lb exedy flywheel. A flywheel bolt had came out recently and jamed up the clutch, and i had to replace the clutch disk, but i never got a look at the flywheel, could it maybe need to be resurfaced?
