heater died
Spec out where the blower motor is under the dash (behind the glove box) and give it a good whack up-side the head. If it starts working, anticipate replacing it, the motor's bruches have worn to nothing.
P
P
This illustration will give you an idea on the installation orientation for the heater/blower case. You should be able to recognize the curved lower case section (for the blower squirrel cage) when you look under the dash. Give it a whack in that area.
http://www.hondaautomotivepart...LOWER
Yup, you're seeing correctly: One motor, two squirrel cages -
P
P
