abs code 48, LR wheel sensor, anyone have one?
My car abs light is on i found out it is code 48 which is LR wheel sensor, can i jsut clean this or get a new one and if so, do i need to bleed the brakes? BTW searched no results for wheel sensor!!!
Modified by Devo94ac at 1:42 PM 1/31/2006
Bleeding the brakes wouldn't have anything to do with that code. Most likely you'll need a wheel speed sensor, but it's possible that it's wiring or something wrong with the tone ring on the hub. If you've got an ohmmeter, do a resistance check on the sensor and see if it falls within specs. I don't know the spec off hand, but it should be in a service manual, or you can compare it to the other side.
Progen
Dec 27, 2013 02:26 AM
