help with ek
ok i have searched but have not gotten a specific answer.
heres my set up:
i have a __97 ek hatch__ i just put and obd1 b16 in, my tach or speedo dont work
- i changed the injectors to obd2
-obd2 dizzy (LS with the ear cut off)
-obd2 alternator
-running ob1 gsr ecu with conversdion harness
-99-00 civic si engine wiring harness
the car runs and starts and i've been driving it for like two weeks with no problem
is theres some kinda of wiring i have to do or something i check spped sensor on tranny i took one of my gsr
heres my set up:
-obd2 alternator
maybe the plug on the harness side for the speed sensor is corroded and you should see if allyou dizzy wires are there it should be like 7 or 8 wires coming out of it
there are 2 blue wires on one of the plugs going to the dizzy, i had each blue wire going to the wrong blue wire. So i just switched them and it worked out
ok heres the deal guys, i bought an 0bd2 LS dizzy and cut off the ear so it works on a vtec motor does it make a diferent on making the rpm works, should i just get an si dizzy, since it an si wiring harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM91civnizzle »</TD></TR><TR><TD CLASS="quote">should get your speed o meter fixed, theyn can tow your car for that</TD></TR></TABLE>
they can really tow it? yeah im trying to fix but i can figure out the problem
Cza_EM1
Jan 9, 2012 08:11 AM
-DC2-
Oct 30, 2007 03:36 AM
=ITRpoweredEK9=
Jan 4, 2006 08:12 PM
