issues with a 93 del sol
Old Jan 23, 2006 | 10:02 AM
fqnjdmboy's Avatar
Default issues with a 93 del sol
So Im working on a friends car,For some reason it has no spark and the fuel pump wont come on...The car has a brand new distributor on it and a brand new fuel pump relay and pump...What could be the problem...Ive tried searching but have came up with no straightforward answers....
Old Jan 23, 2006 | 10:03 AM
nocturnaldragon's Avatar
Default Re: issues with a 93 del sol (fqnjdmboy)
main relay or bad key switch perhaps?
Old Jan 23, 2006 | 10:33 AM
Del Sol SiR's Avatar
Default Re: issues with a 93 del sol (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">main relay or bad key switch perhaps?</TD></TR></TABLE>
Old Jan 23, 2006 | 07:36 PM
fqnjdmboy's Avatar
Ive tried a few different relays..one was brand new oem honda and also tried a few different ecu's...also put my aem ems in it pump came on...what do you think it could be....Im sure that one of the two ecu's other than my aem were good.....
Old Jan 23, 2006 | 07:52 PM
Stoich EG2's Avatar
Default Re: (fqnjdmboy)
how them grounds? add more, couldn't hurt
Old Jan 24, 2006 | 09:24 AM
SOL Food's Avatar
sounds like a main relay issue.
Old Jan 24, 2006 | 10:34 AM
Out of curiousity pull the fuel pump acces cover and make sure your getting voltage to the pump and trace the wires back to the main relay. Its possible to have a break in your wiring some where. Sorry just thought of that.
Old Jan 24, 2006 | 10:55 AM
lsvtecturbosol's Avatar
the aem doesnt really need all the same grounds as the stock ecu needs check to make sure that the ground that goes to the thermostat housing is grounded good then check the ground that goes to the tranny. other than that i dont know what it could be..
DID IT ACTUALLY START with the ems or just turn on the pump
Old Jan 24, 2006 | 09:10 PM
fqnjdmboy's Avatar
Car wouldnt start...pump would infact cycle...So Im at a loss now....the car has all of the proper grounds...Im gonna try yet another ecu...
PetesPonies
Sep 9, 2019 06:36 AM
philztheone
40
Apr 27, 2015 06:57 AM
drhoward07
Jun 4, 2010 01:00 PM
Kendawg386
Jul 25, 2008 06:16 PM
almostjdmeg
Jul 21, 2008 05:19 AM
