question about knock sensor and timing retard
Old Jan 23, 2006 | 08:43 AM
AnAccordIsForever's Avatar
Default question about knock sensor and timing retard
Does this car/engine(signature) have a knock sensor ? and the ability to retard timing if knocking is sensed ?
Old Jan 23, 2006 | 08:45 AM
HondaF1Fanatic's Avatar
Default Re: question about knock sensor and timing retard (AnAccordIsForever)
Yes, all F23 engines have a knock sensor that will retard timing if knock is sensed. They will also adjust for higher octane fuel and increase power with it.
Jon
Old Jan 23, 2006 | 09:39 AM
Default Re: question about knock sensor and timing retard (HondaF1Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaF1Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">Yes, all F23 engines have a knock sensor that will retard timing if knock is sensed. </TD></TR></TABLE>
Thanks Jon.
Can you read my mind or something ?! 'cause thats what I was going to ask next. When exactly and how often does the ecu check for adjusting timing for higher octane fuel ?
Old Jan 23, 2006 | 11:15 AM
Unfortunately I am not extremely knowledgable about the fine details, I just know from seeing dyno plots that our cars will pick up some HP and TQ with 91.
Jon
Old Jan 23, 2006 | 04:47 PM
YeuEmMaiMai's Avatar
all accords prior to 2003 cannot make use of higher octane fuel. Only the 7th gen cars can do that.......
Old Jan 24, 2006 | 10:21 AM
Default Re: question about knock sensor and timing retard (YeuEmMaiMai)
ok thanks.
just out of curiosity - would that apply to my 2001 Acura MDX also ? It has DIS though (dist less ign sys).
Old Jan 24, 2006 | 11:13 AM
NAiL05's Avatar
I would just go with manufacturer rated fuels. Thats usually what the factory ECU is mapped for. Sometimes if you put in higher octane fuel you lose power so you never know.
NA JDM GSR
Sep 5, 2006 09:33 AM
tss201secreto
12
Sep 7, 2005 09:07 PM
EFGeeSeR
Oct 31, 2003 11:49 AM
toooslow
Apr 24, 2003 04:24 PM
