Too much speed for the del sol?
For a couple of months now something inside the passenger side dash area is crackling, popping, buzzing whenever I reach around 60+ miles per hour then goes away when I go under the speed it starts at. Sounds electrical, but I have no idea what it could be and why only at those speeds. The car runs fine. It's stock as a rock right now. Stock computer. Any ideas?
Car is a 1995 Del Sol S
Does it sound like water sizzleing when it hits hot metal??? Might have a fluid leak.
Does it always happen even if the a/c is on? off? heater on? off?
blower motor maybe???
i doubt it is your speakers. if you're giving out noise it should be noticable at all speeds and depends on turning up/down volume.
when you hit 60mph, it's probably something rattling that is loose. check around... i found a screw falling off my door. don't worry about it because eventually you will find it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m1ch431_g »</TD></TR><TR><TD CLASS="quote">May be major or not, but its annoying enough for me to drive under 60 mph just to not hear that god awful noise.
pull out the dash and investigate. there is a lot of stuff in there... perhaps some critters have made a home in there
</TD></TR></TABLE>pull out the dash and investigate. there is a lot of stuff in there... perhaps some critters have made a home in there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m1ch431_g »</TD></TR><TR><TD CLASS="quote">For a couple of months now something inside the passenger side dash area is crackling, popping, buzzing whenever I reach around 60+ miles per hour then goes away when I go under the speed it starts at. Sounds electrical, but I have no idea what it could be and why only at those speeds. The car runs fine. It's stock as a rock right now. Stock computer. Any ideas?
Car is a 1995 Del Sol S</TD></TR></TABLE> Take it to your local tire shop and have the wheels rotated (and balanced, the tires are probably screwed by now). _60 mph_ only affects the balance.
Crasian
10
Feb 17, 2009 08:08 AM
97grnrs
Jan 2, 2006 11:07 AM
