mild steel or chromoly 8 pt and why?
Old Jan 23, 2006 | 06:25 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default mild steel or chromoly 8 pt and why?
93 eg, low 11's, chromoly or mild steel bar and why please. obviously weight, but i was always taught, c-m fatigues easier than mild steel? please explain your response.
Old Jan 23, 2006 | 03:00 PM
racerxadam's Avatar
Default Re: mild steel or chromoly 8 pt and why? (boostedcivicsir)
are you doing it yourself or having it done?
Old Jan 24, 2006 | 03:33 AM
Mr. Badwrench
Default Re: mild steel or chromoly 8 pt and why? (racerxadam)
a very bad *** chassis shop around my way is doing it.
Old Jan 24, 2006 | 04:21 AM
b20turboic's Avatar
If you look for my post about this i asked the same thing. I am saving up and just getting the moly cage because the cage in it self will not really fatigue and weaking too much. If you had a tube chassis built, then with all the suspension binding and body twisting, the moly will fatigue faster and can become brittle and unsafe in a crash. But again the cage will not really fatigue at the same rate due to being welded into your chassis.
Old Jan 24, 2006 | 04:39 AM
k24em2's Avatar
Default Re: mild steel or chromoly 8 pt and why? (b20turboic)
Chromoly is quite a bit stronger than mild steel. If it fatigued and broke, they wouldn't run it in five second top fuel cars.
Mild steel's ultimate tensile strength is around 60,000psi, whereas chromoly is around 85,000psi. Heat treated chromoly can have a tensile strength in upwards of 120,000psi, however heat treating a roll cage is impractical.
Old Jan 24, 2006 | 06:30 AM
1FSTHATCH's Avatar
Chromoly is a stronger metal and to my knowledge, I believe its lighter too...
Old Jan 24, 2006 | 06:55 AM
tony1's Avatar
Default Re: mild steel or chromoly 8 pt and why? (1FSTHATCH)
Only stronger, not lighter. The weight savings comes from using thinner tubing. Where most mild steel needs to be .120 or so, 4130 can be .083.
Old Jan 24, 2006 | 07:04 AM
stealthmode62's Avatar
Default Re: mild steel or chromoly 8 pt and why? (tony1)
Cost vs. Weight I like the mild steel.
Old Jan 24, 2006 | 07:18 AM
Mr. Badwrench
Default Re: mild steel or chromoly 8 pt and why? (stealthmode62)
as do i, the difference between is 300 bucks, install wise also, so that will get me a front bogart wheel, i think i am going to go with mild steel unless the shop sways me otherwise.
racerxadam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">a very bad *** chassis shop around my way is doing it.</TD></TR></TABLE>
I'm close, whats the name of the shop? I'm a weight fanatic so I would choose moly.
Old Jan 24, 2006 | 07:46 AM
Turbocivic94's Avatar
Default Re: mild steel or chromoly 8 pt and why? (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">Chromoly is quite a bit stronger than mild steel. If it fatigued and broke, they wouldn't run it in five second top fuel cars.
Mild steel's ultimate tensile strength is around 60,000psi, whereas chromoly is around 85,000psi. Heat treated chromoly can have a tensile strength in upwards of 120,000psi, however heat treating a roll cage is impractical.</TD></TR></TABLE>
The person who was gonna do my cage said I have to heat treat the complete cage.
Do u really have to heat treat the cage?
Old Jan 24, 2006 | 08:01 AM
racerxadam's Avatar
Default Re: mild steel or chromoly 8 pt and why? (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">The person who was gonna do my cage said I have to heat treat the complete cage.
Do u really have to heat treat the cage?</TD></TR></TABLE>
if the fitup of the joints are good, and the welds aren't too hot you can avoid the need to stress relieve afterward. Read this faq.
http://www.tigdepot.com/faq.html
Old Jan 24, 2006 | 08:37 AM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxadam &raquo;</TD></TR><TR><TD CLASS="quote">
I'm close, whats the name of the shop? I'm a weight fanatic so I would choose moly. </TD></TR></TABLE>
Rhodes Custom Auto Works in Middletown Delaware. looking for al ink.
http://www.rhodescustomauto.com/
Modified by boostedcivicsir at 5:59 PM 1/24/2006
scottsworld7
Welding / Fabrication
Aug 6, 2011 03:31 PM
jdm-ek-si
Mar 14, 2010 07:17 PM
jeffy
27
Oct 5, 2007 08:33 PM
Masta
May 6, 2005 04:06 PM
Buttcrack
Jan 27, 2004 08:52 PM
