oil on plugs
yea... just pulled my plugs to check for detonation or anything else.. insted i found oil on the threads of my plugs just the threads nothing on the tip ... common sense says oil shouldnt be there . does anyone know where the oil is comming from or other common problems leading to oily plugs
yeah i had that problem before, oil all over the plug threads.. I was so worried my motor was going.. .. I changed the 4 spark plug gaskets when i did my valve adjustment and it went away.. they look like 4 small black donut looking gaskets.. take off your valve cover and flip it over.. and you should see them...
