blown engine - b18 bottom on zc head
is it possible? i dont know what engine i can throw my zc head onto. my bottom was built with perf pistons and the top with cams. i blew a piston trhough the side (long story). would i b able to set my head from my dohc zc onto the b18 bottom or a d16?
88 ls IS d16a1... Which is the less power making USDM version of the ZC. D16A1 is a DOHC d-series like the ZC, their the only ones able to interchange top end parts. But You also cant use a D16A1 bottom in your car because the tranny bolts differently to the block
thanks fdor everyoes help. i did the impossible. i swapped a d16a to my ride cus i was desperate to get it running. the tranny had a lot of mods done to it (including retapping). engine mount was the hardest cus i got a block with power steering and had a different type of mount. i also swapped the pistons on to the d16z and polished, ported my head. it runs great. thanks once again for the help
wushubrian
Jun 22, 2006 11:56 PM
