Accord locked door
My door is locked and it is shut and it can't be opened inside or outside with or without key. Door handle feels loose and key turns but door still stays shut. What could be wrong with it? I took door panel off to see what is wrong but everything looks like it should be and it still will not open. Would i have to break the lock off the door connecting to the car? or is there something else i can do?
Modified by srcv4life at 10:07 AM 1/28/2006
The year and model trim and all that would help.. try just going threw the passenger or back door and opening it like that, if it still doesnt open then it has something to do with the inside of the door.. and u would have to take the door panel off, but with out the door being open thast kinda difficult if not impossible.
other then that i couldnt tell ya what to do if u cant get your door open no matter what.. im sure some of these honda gurus can help ya.
ya if anything, they probably just took the metal piece out that connects the handles to open the door, that or broke the plastic piece that connects it *shrugs*
like i was saying it would be easier to know if u can some how get the door panel off
I was thinking, if u cant get the door open.. then just unscrew the handle inside the car should be a phillips screw and then pop it off and if there is a long mettal piece hooked to it by a little plastic piece then u are good on that, unless it got disconnectd on the other side, in which case u would have to take the whole door pannel.. However if the plastic piece is broken or the metal piece isnt connected just do that and it should work..
what year is the accord mines a 95 and i have the same problem but its a 2 door so i cant crawl through the trunk like someone said if u find out whats wrong let me know thanx
My '97 CD7 (coupe) has the fold-down rear seat, as does your's I'm sure. Is there what looks like a key lock on the rear speaker tray behind the rear seat? That's one of your seat releases.
P
P
Mychal71
Mar 20, 2022 01:32 PM
suhteevin
Jan 6, 2009 09:04 PM
