wont start...tried everything i can think of
Old Jan 22, 2006 | 04:29 PM
x_outlaw_x's Avatar
Default wont start...tried everything i can think of
car wont start, battery has 13 volts, 120psi compression across all 4 cylinders, spark to all 4 plugs, fuel pump is priming itself, replaced the coil...any ideas anyone?....im thinking the ecu...if anyone has a p28 or p08 ecu within 10 miles of 92595, that i could just plug into my car to test, ill give you 5 dollars for driving here and letting me plug your ecu into my car to see if it works
Old Jan 22, 2006 | 05:02 PM
x_outlaw_x's Avatar
Default Re: wont start...tried everything i can think of (x_outlaw_x)
its a d16z6 in an 88 crx SI, if that matters...im running the full engine harness from obd1, and the full firewall harness for obd1...no conversion bullshit...just straight obd1 engine and harness running a chipped p28 ecu
Old Jan 22, 2006 | 05:08 PM
JUST2SPOOL's Avatar
I AM A SCAMMER, DO NOT BUY ANYTHING FROM ME.
****Make sure its grounded****
Old Jan 22, 2006 | 05:09 PM
x_outlaw_x's Avatar
all grounds and connections are good...triple checked all of them
Old Jan 22, 2006 | 05:14 PM
Ross 2.0's Avatar
In a Junkyard near you.
Are your fuel injectors Clicking and spraying fuel? Fuel pump running just means the pressure is there, if the injectors arent squirting it won't run.
Old Jan 22, 2006 | 05:15 PM
JUST2SPOOL's Avatar
Default Re: (x_outlaw_x)
When you turn the key you said you here the fuel prime right and then when you try to crank it what does it do.. Does it turn over or no?
Old Jan 22, 2006 | 05:17 PM
x_outlaw_x's Avatar
yes the injectors are clicking open and close, i know because i used the old screwdrive to ear trick, and i pulled the line off of the outlet of the fuel filter and fuel is coming out...i think its down to map sensor, or ecu...i pulled the ecu out and nothing looked fried...im about to go get some new plugs
Old Jan 22, 2006 | 05:18 PM
x_outlaw_x's Avatar
yes, when i crank it it turns over, and battery is fully charged reading 12.7 volts
Old Jan 22, 2006 | 05:19 PM
Ross 2.0's Avatar
have you checked the main relay (click when the check engine light goes off after you turn the key to run)?
Old Jan 22, 2006 | 05:21 PM
x_outlaw_x's Avatar
Default Re: (MooGoCow3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">have you checked the main relay (click when the check engine light goes off after you turn the key to run)?</TD></TR></TABLE>
so when i turn the key to run but before cranking it over after the cel goes off the main relay will click?
Old Jan 22, 2006 | 05:34 PM
x_outlaw_x's Avatar
bump...need to get it running tonight
Old Jan 22, 2006 | 05:42 PM
x_outlaw_x's Avatar
main relay is good
Old Jan 22, 2006 | 05:56 PM
coquitlamEG's Avatar
Are you positive the plug wires are all in the right place?
Old Jan 22, 2006 | 06:12 PM
.Ry's Avatar
.Ry
Default Re: (coquitlamEG)
I had this same issue the other day, it would crank and crank and crank and no go. I knew the grounds were good it was getting gas etc etc. I pushed the clutch and gas to the floor and cranked that bitch over and she finally came to life. Dunno just my $0.02, ill tak em back if ya want
Old Jan 22, 2006 | 06:31 PM
x_outlaw_x's Avatar
Modified by x_outlaw_x at 7:43 PM 1/22/2006
x_outlaw_x's Avatar
yeah plug wires are right
Old Jan 22, 2006 | 06:50 PM
Under_Pressure's Avatar
In order for a engine to start it needs Fuel, spark, compression. U say u have all 3 now it gets more complicated. I don't think its your ecu because u say u have all 3. so I'm suck, Are u backfiring at all or smell gas?? try spraying starter fluid into the IM and start it then other than that IDUNNO o ya replace your plugs and rotor!
Old Jan 22, 2006 | 06:51 PM
x_outlaw_x's Avatar
bump
Old Jan 22, 2006 | 06:52 PM
x_outlaw_x's Avatar
replaced both of those already
Old Jan 22, 2006 | 07:06 PM
95DxSi-R2
Guest
Posts: n/a
timing belt good?
Old Jan 22, 2006 | 07:08 PM
moores55's Avatar
120psi thats kinda low
Old Jan 22, 2006 | 07:12 PM
JayDiem_k20_Dc5's Avatar
From: University of Massachusetts, Amherst, Ma, US of A
Default Re: wont start...tried everything i can think of (moores55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moores55 &raquo;</TD></TR><TR><TD CLASS="quote">120psi thats kinda low</TD></TR></TABLE>
120 psi is very low
I was gonna say, if it isn't turning over then maybe the starter. sorry I can't really help ya out man
Old Jan 22, 2006 | 07:14 PM
x_outlaw_x's Avatar
120 psi is low?...my d15b only had 100 psi
x_outlaw_x's Avatar
timing belt looks brand new
Old Jan 22, 2006 | 07:39 PM
x_outlaw_x's Avatar
bump for answers...did the motor finally just die?
