Broken piston :(
now is the perfect time to build/stoke your bottom end and please if your going to fix your problem get a new piston and dont use the aforementioned adhesives.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
So how do you guys go about fixing these? Will Hondabond work? I think I got some jb-weld around here somewhere. </TD></TR></TABLE>
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">Zip ties and a coat hanger.</TD></TR></TABLE>
lmfao
No.
lmfao
Whats with all these adhesives!?
Just line them up perfectly in the position that it broke off in, use a piston ring compressor and put the piston back into the cylinders. When they are in the cylinders, theres no room for the broken pieces to get out of place, so BINGO.
Good as new .
Good as new .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop »</TD></TR><TR><TD CLASS="quote">give it to chuck norris and he will squeeze it so hard they will fuse back together and be better than when they were new</TD></TR></TABLE>
Because the only thing that can cut chuck norris is chuck norris.
Okay, okay enough with the jokes.
If your serious about repairing it (which I think you arent...)
Replace it. I mean seriously, "repairing" that? Howd it happen? Youd risk putting that back into your motor? Just for starters, whats it gonna do to the cylinder walls?
REPLACE IT. You dont repair that kind of ****, like a bent connecting rod. Unless you have access to a full machine shop, maybe some welders, dont try to fix that, just replace it, and replace the other ones and rings too if i may reccomend.
So....what DID you do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">Do you think silver solder will be good or should I go out and get some rosin core?</TD></TR></TABLE>
are you joking or are you really that stupid?
soldering iron + piston = don't do it.
Looks like you need MORE timing, less fuel and maybe a full tank of 87oct.
Ive used JB kwick to fix my shatterd sleeves before. And I usaly (for ring lands) I stick chewing gum where the pc.'s used to be, then take the ring land and hammer it firmly back into place. I use trident because thats what my dentist reccomends.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper »</TD></TR><TR><TD CLASS="quote">. I use trident because thats what my dentist reccomends.
I find that bubbilicious makes a firmer bond
</TD></TR></TABLE>I find that bubbilicious makes a firmer bond
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sh!ttyLS »</TD></TR><TR><TD CLASS="quote">are you joking or are you really that stupid?
soldering iron + piston = don't do it.</TD></TR></TABLE>
Oh, ok. Do you know where I can borrow a stick welder?
Oh, ok. Do you know where I can borrow a stick welder?</TD></TR></TABLE>
dude... just use a Hot Glue gun. they are $1 at the dollar store
