I need your help!
Old Jan 22, 2006 | 11:54 AM
86si's Avatar
Default I need your help!
I know this is more of a tech post but if anyone can help me its you guys.(sorry Mods) Well after installing my Exedy twin clutch and what i thought would fix any clutch issues i was having it seems no diff. when i rev the car up in gear with the clutch depressed it stars to move forward at like 6k. not just a little i mean it really lunges. i haven't road tested it yet cause its off the road for the winter.
I have changed everything on this god dam car, cable,pedal assembly and cage, you name it i've tried it. i never had this problem with my d-series trans in the same car. any suggestions. is this normal? it just doesn't seem right. i don't want to drive this thing and be locked out of gear at 9500 rpm like i was with my single disc clutch.
Last year left me very discouraged when everytime i went to the track i could not shift this thing. anybody have suggestions?
BTW its a YS1 trans and the 2nd one that does the same thing
Old Jan 22, 2006 | 02:57 PM
nsxmatt's Avatar
Default Re: I need your help! (86si)
Does your cable/pedal assy have enough leverage to fully release the clutch?
Old Jan 22, 2006 | 03:07 PM
86si's Avatar
Default Re: I need your help! (nsxmatt)
thats what i thought and i reinforce the pedal assembly and replaced the cable. the clutch arm looks to be moving plenty. the pedal feels great too
Old Jan 23, 2006 | 02:24 AM
86si's Avatar
bump for some suggestions
Old Jan 23, 2006 | 09:01 AM
littlebluecrx's Avatar
sure you are not over extending the diaphram? try pushing in the clutch not as far, see if that helps. since you are in 1st I doubt it is am trannie issue, sounds like the clutch is not full disengaged, exedy does not recomend a clutch stop, but your setup might need it. good luck...
da9_P
Transmission & Drivetrain
Nov 13, 2014 03:02 PM
86si
Feb 3, 2006 12:04 PM
BrokenRex
Oct 22, 2005 03:23 PM
It's*BOLO!!
Jul 27, 2002 01:23 AM
senpai
Apr 30, 2002 01:15 PM
