P0303 Cylinder 3 Misfire..PLEASE HELP
Old Jan 22, 2006 | 11:16 AM
Vince24L's Avatar
Default P0303 Cylinder 3 Misfire..PLEASE HELP
So yesterday I was coming home on the highway and my check engine light comes on and flashes. i pulled over and my car was sputtering at a stop. and idle's real low. advanced/Autozone was closed already so i parked it for the night..this morning i went to advanced and tested my OBD2 sensor and the results were:
P0303 CYLINDER 3 MISFIRE
P1399(pending) manufacturer control ignition system or misfire
I replaced the spark plugs but that did nuthing.
Anyone have any idea or seen or heard of anyone having P0303 and fixed it?
after searching there were no real answer.
Any help is appreciated.
-vince
Old Jan 22, 2006 | 11:22 AM
Integra Integra's Avatar
Default Re: P0303 Cylinder 3 Misfire..PLEASE HELP (Vince24L)
I had a cylinder 3 misfire not too long ago and I replaced the plugs, wires, dizzy cap and rotor, fuel filter and PCV valve on it and it solved it no more CEL.
Good Luck
Old Jan 23, 2006 | 11:27 AM
Vince24L's Avatar
Default Re: P0303 Cylinder 3 Misfire..PLEASE HELP (Integra Integra)
anyone else..please. im taking it to a shop now but its only a muffler shop they wont know anything...really need someones advice
Old Jan 23, 2006 | 11:45 AM
M Coop's Avatar
I could be wrong but I would think that it's probably something with the Distributor (maybe a new cap and rotor would fix it). Other possibility could be the ECU I guess but I'm not sure.
Old Jan 24, 2006 | 08:48 AM
Vince24L's Avatar
Default Re: P0303 Cylinder 3 Misfire..PLEASE HELP (M Coop)
no one with some help?
Old Jan 24, 2006 | 09:18 AM
DeDonDeRosa's Avatar
that happened to me a few days ago my number 3 spark plug wire was falling off the dizzy!!!
Old Jan 24, 2006 | 10:19 AM
juicy.fn's Avatar
Default Re: P0303 Cylinder 3 Misfire..PLEASE HELP (DeDonDeRosa)
I had this problem for so long. And failed Emisions becasue of it.
so what i did was replace the cap, rotor, plugs and wires with OEM replacement parts. Still the light came on.
So i got frustrated and took it to Acura. They told me it was a "dummy light" and that they would fix this problem. Then a few days later the light came on again. Took it back to them and they switch the injectors aroung. light never came back on.
try switching the injectors around. worked for me
Old Jan 24, 2006 | 11:31 AM
Ruben19's Avatar
pull out the spark plug for cylinder #3 and see the condition.
if it has carbon deposits is electrical misfire.
change the cable, cap and rotor. maybe the cap tooth inside the cap is broken.
if yu see oil is something else....
Old Jan 24, 2006 | 11:33 AM
Ruben19's Avatar
check all the electrical and if nothing works out
next step will be fuel injectors
Old Jan 24, 2006 | 11:48 AM
oldschoolac's Avatar
check all ignition parts and could be ecu or maybe even be a bad valve(i have seen it before) Can do a simple compression test to rule that out. Good Luck
Old May 14, 2025 | 10:33 AM
C1d's Avatar
C1d
Originally Posted by Vince24L
no one with some heitlp?
it's probably a fuel injector
Tucker33
Dec 16, 2013 09:40 AM
h3rsh3y2001
Sep 14, 2008 06:29 PM
hans_schuller
Jul 30, 2008 07:41 AM
Blown383
Mar 12, 2008 10:20 PM
purple98ek
Mar 19, 2006 07:04 PM
