removing the dash, do i have to remove the climate control?
Old Jan 22, 2006 | 09:15 AM
Sinner's Avatar
Default removing the dash, do i have to remove the climate control?
I cant seem to get the climate controls out, it seems like there are some screws or bolts behind it. How do i remove the climate controls? is it nessessary for removing the dash?
Old Jan 22, 2006 | 09:32 AM
maniefrizzle's Avatar
Default Re: removing the dash, do i have to remove the climate control? (Sinner)
i'm pretty sure you have to remove the climate control first. behind the hazard and defrost buttons are two screws. there is a better explanation on team-integra.net, just search its out there.
Vi3tboy's Avatar
which part of the climate control are you talking about? yes it all has to come out. dont forget the little ***** that you use to slide the temp and how hard its blowing off too. and disconnect all harneses before pulling.
Old Jan 22, 2006 | 10:30 AM
shyboy817's Avatar
Pop out the hazards/defrost button and disconnect the harness. There's a 10mm bolt / or screw i forgot on each side behind those buttons. On the passenger foot area top left corner, there should be a black wire, unclip that and pull off the climate control.
Actually here's a link with pictures
http://www.team-integra.net/se...D=586
Old Jan 23, 2006 | 07:45 AM
Sinner's Avatar
thanks! that last post saved the day!
TEAM EoR
Apr 12, 2008 11:26 AM
preludepower
Oct 14, 2005 09:17 PM
ner0x
Jun 23, 2005 07:17 PM
Zoso1977
Nov 6, 2004 10:57 PM
Mr Boston
20
Oct 9, 2003 05:33 PM
