OEM JDM exhaust manifold for SOHC 88-00 (bigger runners than USDM) Look~!
Old Jan 22, 2006 | 08:31 AM
unrefined7's Avatar
Default OEM JDM exhaust manifold for SOHC 88-00 (bigger runners than USDM) Look~!
Have no use for this…laying around. This is a exhaust manifold from a JDM SOHC motor. This manifold is good for 5-10 hp over the stock manifold and will still retain that factory Honda look. The ports on this manifold are 48mm compared to 38 mm on the us model unit. This will fit civics from 88-00. IF you look at the picture the unit on the right is the JDM one. Notice how much bigger the runners are. This JDM Manifold does accept O2 sensor, It is in the back of the manifold facing the block. I also have a o2 block off screw along I’m giving you. 30$ shipped... 20$ picked up. OBO.
edit: both front and rear heat shields are included.
Modified by unrefined7 at 10:30 PM 1/22/2006
Old Jan 22, 2006 | 08:53 PM
unrefined7's Avatar
Default Re: OEM JDM exhaust manifold for SOHC 88-00 (bigger runners than USDM) Look~! (unrefined7)
bump
Old Jan 23, 2006 | 06:14 AM
unrefined7's Avatar
ttt
Old Jan 23, 2006 | 09:04 AM
unrefined7's Avatar
thump
Old Jan 23, 2006 | 03:07 PM
unrefined7's Avatar
Old Jan 23, 2006 | 05:44 PM
unrefined7's Avatar
Old Jan 23, 2006 | 05:58 PM
Charlie Moua's Avatar
Default Re: OEM JDM exhaust manifold for SOHC 88-00 (unrefined7)
weird...
bump for you
Old Jan 24, 2006 | 06:29 AM
unrefined7's Avatar
up
Old Jan 24, 2006 | 10:22 AM
unrefined7's Avatar
up up up
Old Jan 24, 2006 | 06:08 PM
unrefined7's Avatar
come on now...i know somebody wants this.
Old Jan 24, 2006 | 06:44 PM
.xcalibur.'s Avatar
check PM's
Old Jan 24, 2006 | 10:13 PM
unrefined7's Avatar
Default Re: OEM JDM exhaust manifold for SOHC 88-00 (.xcalibur.)
replied
the soL that could
Feb 5, 2006 08:31 AM
unrefined7
Jan 24, 2006 06:08 PM
dub204
Mar 8, 2005 03:00 PM
JICB16B
Jan 22, 2004 11:04 AM
