jdm itr tranny
Old Jan 21, 2006 | 08:06 PM
95DxSi-R2
Guest
Posts: n/a
Default jdm itr tranny
how do i know if the tranny is really a jdm itr tranny?
Old Jan 21, 2006 | 08:13 PM
MiraiZ's Avatar
Default Re: jdm itr tranny (95DxSi-R2)
compare mph-rpm ratios
Old Jan 21, 2006 | 08:15 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: jdm itr tranny (MiraiZ)
huh
well them what should they be. I have a jdm b16 right now with jdm itr trans
Old Jan 21, 2006 | 08:59 PM
ITR#132's Avatar
If there use to be a VIN number attached to the tranny, its not JDM. Look for the threaded holes.
Old Jan 21, 2006 | 11:17 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: jdm itr tranny (ITR#132)
thats what i thought
it used to have a tag, but it does have lsd
Old Jan 21, 2006 | 11:18 PM
95DxSi-R2
Guest
Posts: n/a
so how do i know it's a usdm itr, actually, they didn't offer gsr or si lsd usdm did they?
Old Jan 22, 2006 | 04:15 AM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 &raquo;</TD></TR><TR><TD CLASS="quote">If there use to be a VIN number attached to the tranny, its not JDM. Look for the threaded holes.</TD></TR></TABLE>
I don't think brand new replacements from the dealer have threaded holes for vins. So it could still possibly be a USDM tranny.
OP, does your tranny say J4D on it or N3E?
Old Jan 22, 2006 | 08:22 AM
95DxSi-R2
Guest
Posts: n/a
Default Re: jdm itr tranny (88 rex)
http://www.hondaswap.com/forum...29829
it has the threaded holes for the vin plate, so it's usdm and the only available lsd usdm trans is the type-r
thanks for the help though
Modified by 95DxSi-R2 at 2:05 PM 1/22/2006
Old Jan 22, 2006 | 10:12 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote">thats what i thought
it used to have a tag, but it does have lsd</TD></TR></TABLE>
If to can see through the axle holes, it has an LSD. If there is a pin between the axle holes, it is an open differential.
Old Jan 22, 2006 | 01:10 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: jdm itr tranny (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
If to can see through the axle holes, it has an LSD. If there is a pin between the axle holes, it is an open differential.</TD></TR></TABLE>
I already knew that part
Old Jan 22, 2006 | 01:24 PM
88 rex's Avatar
Then all that really matters is what you year, b/c the USDM = 96-97 JDM hype R tranny. 98+ had different gears.
9db85
Jul 12, 2009 01:10 PM
Fastwhip
Jul 19, 2006 02:39 AM
kcjohnnyboy
Nov 5, 2005 11:41 AM
98R-641
Jul 12, 2002 05:17 AM
SPOON_BeIgHtEeNsEe
Dec 27, 2001 03:23 PM
