my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!!
From: The Real O.C. Oakland Chinatown, California, USA
it all started with a leaking master cylinder. then i replaced that, and found out the slave was also gone, so i replaced that. after that, i took it for a drive and it was fine for around 5 minutes, then it had to be forced into gear, and would shake while in gear with the clutch fully down and the car at a stop. one of my friend recommended to take out the tranny and replace the throw out bearing. come to find out the throw out bearing was totally gone, and i replaced it and poured mth fluid in it. took the car out for a drive, had to be around 30-40 minute drive, everything was perfect. couple days later, i'm starting to have the same problem, it would have to be forced into gear after 5 minutes into the drive. so i thought it was the slave, since the slave was bought used and was from a 10 yr old car. replaced it and still having the problem. PLEASE HELP ME, IM BEGGING YOU!!! i'm so fustrated right now....
i'm sure i gave it enough fluid, and i checked for leaks, and everything looks good. fluid stays the same level in the resivoir so i'm pretty sure there are no leaks.
my transmission is having problems also....this happened two days ago....when i was driving to work and i was going into 5th gear, it wont go in and i had to push harder to get into the gear....i was upset when i had to do this, sometimes i can pop in gear smoothly, other times its harder to get into 5th gear and i have to push harder to get it in....my co workers say i need to get a transmission flush and get thicker fluid...does anyone know or have any suggestion to this problem
candy eg
Jan 23, 2006 09:56 AM
candy eg
Jan 23, 2006 08:02 AM
candy eg
