Replacing Rear Caliper Dust boot??
Old Jan 21, 2006 | 06:22 PM
TurBoTeG's Avatar
Default Replacing Rear Caliper Dust boot??
Im trying to replace the dust boot on a rear 94 integra caliper. I cannot get the boot into the goove for the life of me...is there a trick to get it in???
Old Jan 21, 2006 | 07:45 PM
mrlegoman's Avatar
Default Re: Replacing Rear Caliper Dust boot?? (TurBoTeG)
I always just rotated the boot around till it worked itself in. I know that doesn;t help much, but that's all I got.
Old Jan 21, 2006 | 10:13 PM
TurBoTeG's Avatar
anyone else???
Old Jan 22, 2006 | 05:31 AM
TurBoTeG's Avatar
up
Old Jan 22, 2006 | 08:13 AM
IMALLSLO's Avatar
Default Re: (TurBoTeG)
Use compressed air. Place the boot in the grooves......hold the lubed piston just above the seal and blow compressed air(ie from a compresser) in through the brake line port. This will balloon the seal up and over the piston. Note: Keep fingers inside of the caliper edges. If the air is to much or you miss the seal youll crush/squeeze you fingers off. :&gt Hvae fun.
Str8 outta Cliff
Suspension & Brakes
Jul 22, 2009 03:28 PM
tlmadness
Jul 7, 2007 04:58 PM
hondmywrld
Apr 2, 2007 10:15 PM
maxdb
Apr 28, 2005 04:16 PM
