Suggest a good air filter...
Old Jan 21, 2006 | 06:20 PM
four o two's Avatar
Default Suggest a good air filter...
Hey guys, I'm gonna grab an el-cheapo intake tube off of eBay for my '97, and I need some suggestions on a good air filter to use. If you recommend something, please give me help on what size to get. I assume most intakes have a 3" inlet, but how long should the filter be, tapered/not tapered, stuff like that...
Old Jan 21, 2006 | 06:24 PM
vinuneuro's Avatar
Default Re: Suggest a good air filter... (four o two)
Apexi or K&N
Old Jan 21, 2006 | 06:28 PM
four o two's Avatar
Default Re: Suggest a good air filter... (vinuneuro)
Size? I already have K&N / Apexi in mind. I need a general size, and a place to order.
Old Jan 21, 2006 | 06:44 PM
The Weather Man's Avatar
Size?.............
what size is your intake?
Old Jan 21, 2006 | 07:42 PM
four o two's Avatar
Default Re: (TheKINGPin)
Read much? Most ones I see are 3" for the flange. I need to know how long of a filter to get. Not brain surgery folks.
Old Jan 21, 2006 | 07:54 PM
92hondalude's Avatar
Default Re: (four o two)
if you go with apexi i think there are no differences in the length.
a 3" is a 3'
Old Jan 21, 2006 | 07:59 PM
hu's Avatar
hu
^There was a test done that showed apexi as giving the most power and best filtration. I will try to find the test and link it here.
Old Jan 21, 2006 | 08:03 PM
four o two's Avatar
Default Re: (hu)
I've seen that pic.
Old Jan 22, 2006 | 07:29 AM
axtran's Avatar
Default Re: (hu)
i don't know, but with my old vw a K&N that fit inside the stock airbox was just the best you could do
Old Jan 22, 2006 | 07:44 AM
BB6racer's Avatar
what type of intake are you getting? short ram or cold air? when i got my aem short ram intake for my 98 the filter that came with it hit the headlight housing, so i had to cut off about 1.5" from the intake pipe. an aem cold air intake's filter is a little longer, about 2' i think, and it sits veru close to the splash guard. i would say that no matter what length filter you get, you can make it fit either by sliding it a little further along the intake pipe, or cutting the pipe shorter like i did. besides most filters i have used were pretty close in length.
GoLowDrew
Jul 9, 2013 08:40 PM
RICO_
Honda Civic (2006 - 2015)
10
Jun 10, 2009 04:57 PM
chadsxe
16
Aug 27, 2007 11:13 PM
Jay2005
Dec 19, 2006 11:17 AM
