92 integra gsr help!
I have a 92 acura integra GS-R, Does it come with stock LSD? also, I had a problem with my vtec not kicking on and my rev limiter engaging at 7400 instead or 8200, I changed pressure switch, solenoid and temp sensor, but it still doesnt work. I hot wired the vtec but the rev limiter still kicks on way too early.....please help
Thank You
Josh Landrum
Untamed Imports
does your v-tec kick? and if your rev limiter is around 7000 check your ECU it might be a ls? haha... just a thought... i heard a lot of pplz that sell their gsr usually throw a ls ecu on it b4 they sell it. if that not it, maybe your oil level is low like aznballer said.
has gsr ecu, have full oil, speedo sensor is out.....it use to work then it just stopped....i think some wires fried from a loose battery connections.....will that have a effect on rev limit and vtec engagment?
if so anyone know where i can get GSR harness.....also i need a blitz front bumper only.
Thank You For Your Time
