how to get check engine light to go out or reset
Old Jan 21, 2006 | 02:42 PM
kizner's Avatar
Default how to get check engine light to go out or reset
can you reset the ecu somehow to get check engine light to go out on a 97 hatch
Old Jan 21, 2006 | 03:46 PM
blkSi's Avatar
if your cel is on then chances are there might be something wrong. unless youre talking about the "maintenance required" light, in which case you just stick your key in the hole below it to reset it to green
you also might not have clicked your gas cap 3 or more times the last time you put gas in it. it should take a couple trips to go off
Old Jan 21, 2006 | 04:08 PM
ReggieGrip's Avatar
Default Re: (blkSi)
disconnect your negative on your battery
Old Jan 21, 2006 | 04:10 PM
97spooncivic's Avatar
Default Re: (ReggieGrip)
you can with an obdII scanner
Old Jan 21, 2006 | 04:16 PM
1Ek 1Eg's Avatar
does it turn red when it needs maintenance, cuz it looks like its red on mine.
Old Jan 21, 2006 | 04:42 PM
Default Re: (Brinks07)
thats the maintance, that means you need a check up and oil change blah blah blah
Old Jan 21, 2006 | 04:45 PM
spoonracer84eg's Avatar
Default Re: (97spooncivic)
Do all your maintenance then stick your key in the reset next to the red thing. It will turn green again.
Old Jan 21, 2006 | 05:16 PM
1Ek 1Eg's Avatar
its the same for a 96 ek right?
Old Jan 21, 2006 | 05:18 PM
yea
Old Jan 22, 2006 | 04:25 AM
kizner's Avatar
its def the check engine light, i put a new o2 sensor in rear, didnt have one in there, so the check engine light was on. now that i put one in there do you have to have obd II scan tool to reset.
Old Jan 22, 2006 | 06:56 AM
Chiovnidca's Avatar
Default Re: (kizner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kizner &raquo;</TD></TR><TR><TD CLASS="quote"> do you have to have obd II scan tool to reset.</TD></TR></TABLE>
No, just disconnect the battery for a bit.
Old Jan 22, 2006 | 09:07 AM
Default Re: (Chiovnidca)
doesnt that make the srs light comne on?
Old Jan 22, 2006 | 09:18 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97spooncivic &raquo;</TD></TR><TR><TD CLASS="quote">doesnt that make the srs light comne on?</TD></TR></TABLE>
Nope.
Old Jan 22, 2006 | 09:28 AM
Ninety5Ex's Avatar
make sure you have your radio code if you have factory radio
Chadted
Honda Civic (2006 - 2015)
Jul 14, 2009 10:06 AM
jamzm101
Apr 2, 2007 12:00 PM
pens81
Acura TSX
Mar 30, 2006 03:42 AM
91civicmaine
Mar 16, 2006 09:37 AM
pec pec
Jan 31, 2006 07:46 PM
