walbro fuel pump
Old Jan 21, 2006 | 12:22 PM
cbrodac0424's Avatar
Default walbro fuel pump
ok so i have a question for you guys i have a walbro fuel pump part number gss341 it is a universal and i was wondering if this would work on a 2002 rsx type-s it has a greddy turbo kit on it and the duty cycle is 80% and i am running 6 pounds on it but i was wondering if the pump will work for me?? TIA
Edit: ok sorry brain fart it is the 2002 type-s
Chris
Modified by cbrodac0424 at 9:33 PM 1/21/2006
Old Jan 21, 2006 | 12:29 PM
SpoonyDC5's Avatar
Default Re: walbro fuel pump (cbrodac0424)
they dont make 2001 rsx-s so no it wouldnt ........in 01 the rsx was merely a concept but i dont about your fuel pump prob
Old Jan 21, 2006 | 01:04 PM
200 HP's Avatar
Default Re: walbro fuel pump (SpoonyDC5)
it'll work on your car but i doubt u need it for only six pounds...what kind of injectors are you running?
Old Jan 21, 2006 | 03:31 PM
NJslvrtypes's Avatar
Ahh I'm not sure if it would work. The Walbro that you should have ordered is the GSS342 which is also universal but only requires minimum modification to fit in the stock location.
You could also bump your injectors up to RC 650's or even 550's and forget about the fuel pump.
Old Jan 21, 2006 | 06:38 PM
Default Re: walbro fuel pump (NJslvrtypes)
the injectors are 660's i got the pump for 30 bucks not a bad deal i think and the boost its being turned up to 14 pounds
Old Jan 21, 2006 | 09:19 PM
Holy crap, thats a high duty cycle for 660's and a greddy kit.
I don't know much about the GSS341 because I'm using the 342. Your going to have to pull the stock pump and take a look.
Good luck with 14 psi though. Should run good.
ABK
17
Jul 28, 2020 08:00 PM
Ek4 life
15
Jul 17, 2008 05:14 PM
Boilermaker1
Honda Civic (2001 - 2005)
Nov 28, 2006 09:41 AM
dc9turbo
Nov 22, 2004 09:17 AM
Btothe3rdDegree
Jul 29, 2004 09:08 AM
