universal oxygen sensor for downstream what wires colors are what
Old Jan 21, 2006 | 10:53 AM
kizner's Avatar
Default universal oxygen sensor for downstream what wires colors are what
on factory plug on 2nd o2 sensor the wires are red, white, black, black. which ones are heaters, ground, sensor(ecu)
Old Jan 21, 2006 | 11:09 AM
civicious's Avatar
Hold that plug up to the plug for the primary o2 sensor, and compare the colors.
2 black = heater (ECU pin A6, ignition)
white = o2 signal (ECU pin D14)
green = o2 ground (ECU pin D22)
Old Jan 21, 2006 | 11:19 AM
built562's Avatar
Default Re: (civicious)
you need to find the original pinouts, then compare to the wiring chart given with the universal, when i did my universal i used a bosch and it had 2 grays, green, white. you just need both wiring diagrams
Old Jan 22, 2006 | 04:22 AM
kizner's Avatar
thanks, that seems to work
holmesnmanny
Aug 7, 2012 10:55 PM
robbizza
Aug 29, 2006 08:58 PM
pyrojeff
May 17, 2004 06:30 PM
Mentat Ghola
Apr 11, 2004 10:58 AM
