broken gas needle on si cluster..
well a couple of days ago i was putting in my si cluster in and the f*king gas needle broke..
...is there a way to fix it or can i just leave it like that and wait till the gas light goes on...will the gas light even go on???..help!thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">You have gas light? What do you mean the needle broke? Did it physically come off? Or did it just stop working?</TD></TR></TABLE>
Yea si cluster have a gas light
well it physically broke off
.. so will the light go on if im low on gas if the needle is broke..or does the gas light read off the needle
My fuel sending unit in my car is bad, so my fuel gauge doesn't always read correctly. Yet, my gas light still comes on when fuel is low. It doesn't read from the F.S.U. or the needle. The gas light will still let you know when fuel is low.
Although, my fuel light is on about 95% of the time in my truck, and I need to replace the F.S.U. I just know when to fill up.
Anyhow, again, to answer your question, the fuel light will come on when it is time to fill up, it doesn't read off of the needle.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1dayCivic »</TD></TR><TR><TD CLASS="quote">Hmm, Maybe you could take the Needle off of your old cluster and swap it on? Just an idea. I'm probably wrong on that. </TD></TR></TABLE>
It would need to be recalibrated. Or done very carefully
. Actually, I am not sure how it works, but if it is anything like a speedo or tach, it would have to be recalibrated.
-Shane
. Actually, I am not sure how it works, but if it is anything like a speedo or tach, it would have to be recalibrated.-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">My fuel sending unit in my car is bad, so my fuel gauge doesn't always read correctly. Yet, my gas light still comes on when fuel is low. It doesn't read from the F.S.U. or the needle. The gas light will still let you know when fuel is low.
-Shane</TD></TR></TABLE>
cool.l
so replacing the needle wont have to be done..
will it be something hard to do to take the needle of the old cluster and put it on the si cluster
cool.l
