Throttle body swap
I have searched around but havent really found my answer. I have a obd1 jdm b16a that needs a throttle body. Will a throttle body from a obd1 LS Integra bolt right on it. If so is the LS tb the same size and lastly does the map sensor bolt on top of the LS tb or is it mounted on the fire wall like the jdm b16a. Thanks guys
94-01 Integra LS/GSR AND All B16 throttle bodies are all the same size. They all utilize the top mounted MAP sensors, and are all swappable. The only ones that use the Firewall MAP are the B18A1 (2g Teggy).
Also swappable are H22 Throttle Bodies, though im not sure of the size difference, if any.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealth_EK4 »</TD></TR><TR><TD CLASS="quote">all b16 and b18 TB's are the same just that the gsr and type r's are bigger in dia. but they will all bolt up</TD></TR></TABLE>
b16b is larger too
b16b is larger too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt »</TD></TR><TR><TD CLASS="quote">
b16b is larger too</TD></TR></TABLE>
yes like i said type R's
as in civic and integras
Sanj
Sep 29, 2005 09:03 PM
