JG edelbrok intake manifold + STR 68mm TB...what throttle cable??
Old Jan 20, 2006 | 08:14 PM
TurBoTeG's Avatar
Default JG edelbrok intake manifold + STR 68mm TB...what throttle cable??
Im using JG edelbrok intake manifold + STR 68mm TB...what throttle cable should i be using? I heard the LS and ITR throttle cables are the same length and the GSR is longer. Who here has a similar setup and what cable did you run?
Old Jan 21, 2006 | 05:07 AM
Bradstard's Avatar
Default Re: JG edelbrok intake manifold + STR 68mm TB...what throttle cable?? (TurBoTeG)
I have the JG manifold with an RPM Services 72mm TB and I am running my stock ITR throttle cable. No problems, everything is fine. I had to bend the bracket a bit to make everything line up properly.
Old Jan 21, 2006 | 06:02 AM
RTW DC2R's Avatar
when I was running the JG IM and a BBK TB, the throttle cable was pretty short, not much room for play. I was told older integras have longer throttle cables, but I never tried to swap it.
https://honda-tech.com/zerothread?id=609212
Old Jan 21, 2006 | 02:30 PM
TurBoTeG's Avatar
thanks guys!
Old Jan 21, 2006 | 03:31 PM
Krucial_Ek9's Avatar
hmm
1slow_ej8
Jun 7, 2007 10:04 PM
TurboIntegra
Jul 21, 2006 03:25 AM
Autoworks
Mar 10, 2005 04:19 PM
Ls1 FD3s
Jan 15, 2005 10:51 PM
SIReg9
Oct 9, 2003 08:16 PM
