annoying rattle in 94 coupe
Old Jan 20, 2006 | 06:04 PM
teler86's Avatar
Default annoying rattle in 94 coupe
i have this annoying rattle that sounds like a heat shield on my 94 coupe which one could it be i already removed the ones off of the the exhaust manifold
Old Jan 20, 2006 | 07:20 PM
transpar_nt's Avatar
Default Re: annoying rattle in 94 coupe (teler86)
Most likely right underneath your shifter around your exhaust.
Old Jan 20, 2006 | 07:58 PM
bmiller17's Avatar
Default Re: annoying rattle in 94 coupe (transpar_nt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt &raquo;</TD></TR><TR><TD CLASS="quote">Most likely right underneath your shifter around your exhaust.</TD></TR></TABLE>
thats probably what it is, there is a heat shield around your catalytic converter
Old Jan 24, 2006 | 02:08 PM
teler86's Avatar
Default Re: annoying rattle in 94 coupe (bmiller17)
is it easy to take off
Old Jan 24, 2006 | 02:29 PM
bmiller17's Avatar
yeah its pretty easy, i think its 6 nuts you would have to take off, i think they are 10 mm, they might be 12. You could also just look at it and see if its touching anything that would make it rattle and you could just bend it back if you dont wanna take it off.
Old Jan 24, 2006 | 04:52 PM
SOL Food's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmiller17 &raquo;</TD></TR><TR><TD CLASS="quote">yeah its pretty easy, i think its 6 nuts you would have to take off, i think they are 10 mm, they might be 12. You could also just look at it and see if its touching anything that would make it rattle and you could just bend it back if you dont wanna take it off.</TD></TR></TABLE>
Old Jan 30, 2006 | 08:46 PM
teler86's Avatar
Default Re: annoying rattle in 94 coupe (MARSH)
there is no disadvantage to taking it off right?
Old Jan 30, 2006 | 08:49 PM
poison's Avatar
No. other than a quarter of an ounce weight reduction if you want to get technical.
turboy7
Sep 4, 2008 06:07 PM
vdawg559
Dec 31, 2007 07:41 PM
z6honda
Sep 20, 2005 08:25 PM
DjN3M3S1S
Audio / Security / Video
Jul 23, 2004 07:10 AM
Methadron78
Jan 31, 2004 06:55 AM
