No spark issues.... related to timing break???
Old Jan 20, 2006 | 05:11 PM
Dropped90Integra's Avatar
Default No spark issues.... related to timing break???
Ok, its a 90 Accord EX Automatic, the timing belt snapped on this thing. A friend of mine put a new belt back on but now he's not sure if the timing is correct but its not getting spark. Would the timing being maybe way off not give spark??? I tested the 2 wire plug to the dizzy with a test light, one has power the other doesn't which I'm assuming power/ground correct?? Any ideas here, he tryin to get this car back on the road.
Old Jan 20, 2006 | 06:38 PM
hondadude's Avatar
Default Re: No spark issues.... related to timing break??? (Dropped90Integra)
If the cam is turning the distributor shaft you shouild have spark, now if that spark is in time with the crank stroke is a different problem.
Old Jan 20, 2006 | 08:20 PM
I3ooS710's Avatar
Default Re: No spark issues.... related to timing break??? (hondadude)
You should have spark regardless. Check your ignitor to see if it's burnt out.
Old Jan 20, 2006 | 08:27 PM
Thats the issue, the camshaft is turning but no spark at all and the dizzy is getting power is thats the correct plug I meantioned that I checked for power. Now, he changed out the dizzy with a working one that he def. knows that works & nothing either. Its really puzzling cause the car was fine before the belt broke and now the belt is on and its no spark at all.
Old Jan 20, 2006 | 08:28 PM
by the way.... anyone have a link to the timing picture for a 90 Accord?
Old Jan 21, 2006 | 09:24 AM
anyone have a clue here... my friend trying to get it back running ASAP
migric
Jun 29, 2018 01:01 AM
avatar1
Engine Management and Tuning
10
Jan 24, 2011 03:11 PM
spork motorsports
Mar 28, 2007 10:03 PM
CRXcamaro
Aug 6, 2006 10:51 AM
DetroitPOScivic
37
Jun 10, 2004 08:07 AM
