Sport mode light blinking..
Old Jan 20, 2006 | 05:11 PM
upncomer's Avatar
Default Sport mode light blinking..
Hi All, it seems my sport mode light blinks on and off now and wont stop when i am driving, but the transmission shifts fine. Is this a common code pattern on Accords thats telling me a specific part needs replacing? It seemed to happen when installed a new battery, but after I tried disconnecting the battery again the light still remains blinking. Also, where is the trans fluid dip stick at? Can't seem to locate it on the car to check the level...thanks in advance.
Steve
Old Jan 20, 2006 | 06:17 PM
hondadude's Avatar
Default Re: Sport mode light blinking.. (upncomer)
The trans dip stick is hidden behind the lower radiator hose, check the fluid level with engine off. here's a link so you can get the trans code.
http://members.troublecodes.ne...n.jpg
It might help to know what year make and model you have, XXX miles,prior main't
, etc.
Old Jan 21, 2006 | 02:43 AM
upncomer's Avatar
Default Re: Sport mode light blinking.. (hondadude)
Hey, thanks...I have a 90' Accord by the way.
Steve
Old Jan 21, 2006 | 08:35 AM
P_Adams's Avatar
Possible Main relay, Ignition switch issue
There could be an intermittent TCU power supply problem. Check all power supply inputs to the TCU and/or the TCU capacitors
Old Jan 21, 2006 | 03:24 PM
upncomer's Avatar
Default Re: Sport mode light blinking.. (P_Adams)
Thanks, I'll check that tomorrow...I think it it could definitely be electrically related since I have had some issues with the battery connections and wiring recently.
follie gatts
Feb 6, 2009 08:39 PM
pellet36
Aug 31, 2008 12:44 PM
nyzd79
Nov 22, 2007 03:42 PM
total-assault
Jul 21, 2007 09:48 PM
tvrsir
Apr 8, 2002 05:26 PM
