ABS light on
Old Jan 20, 2006 | 04:14 PM
jojo69's Avatar
Default ABS light on
Hi all,
93 accord EX, Automatic
The ABS light went on.
Brake pedal is low.
Any idea how to check for bad wheel sensor?
Which side is the bad one?
Does a wheel sensor effect brake pedal? (high and performance)
thanks,
Joe M.
Old Jan 20, 2006 | 04:19 PM
YeuEmMaiMai's Avatar
Default Re: ABS light on (jojo69)
if your pedal is low I would check to see if you have a leak or air in the system first. usually a soft pedal indicates air in the system.
Old Jan 23, 2006 | 03:16 PM
jojo69's Avatar
Default Re: ABS light on (YeuEmMaiMai)
What is the best way to check for leak in the breaks?
Thanks
Old Jan 28, 2006 | 06:25 PM
jojo69's Avatar
Just noticed Brake pedal is not just low, sometimes it is high but if I keep pressing it, It goes down.
Is the master cylinder is bad?
thanks for your help
malilaz
Suspension & Brakes
Nov 23, 2013 12:42 AM
G0TB00ST
Feb 9, 2009 10:59 AM
my93accord
Jan 5, 2009 08:00 AM
98LS4dr
Oct 14, 2004 05:38 PM
